Activity Forums Apple Final Cut Pro Editing and dividing a job in scenes .
  • Editing and dividing a job in scenes .
    Posted by Fredy Schwerdtner on August 2, 2011 at 5:06 pm
    Hi guys.
    If I want to edit a video, scene by scene and in the end do a final “timeline” adding all scenes, will I have to create as many “projects” as scenes that I have on my video ?
    On FCP7 I could divide / organize the scenes by bins and timelines inside bins, that is why I’m asking it.
    Thanks everyone in advance.
    iMac 2.7 GHz Intel 4 Core i5
    16 GB memory
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    6GB 667 MHz DDR2 SDRAM
    OWC RAID 5 with 3TB
    (2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
    OS X 10.6.5
    Final Cut Studio “3”
    David Battistella replied 15 years, 1 month ago 3 Members · 5 Replies
  • Craig Seeman
    August 2, 2011 at 7:53 pm
    Projects are timelines and you can cut and paste. Some have found setting up Compound Clips in the Event Browser (as opposed to the timeline) as one method of working.
  • Fredy Schwerdtner
    August 2, 2011 at 8:16 pm
    So, my “timeline scenes” will be projects.
    Compound Clips are “legacy Nest Sequence”, right ?
    So, I should make a compound clip out of my scene projects, copy&paste to a final project. Am I right ? lol
    16 GB memory
    MacBook Pro 17″
    OWC RAID 5 with 3TB
    OS X 10.6.5
  • Craig Seeman
    August 2, 2011 at 8:40 pm
    You can make Compound Clips in the Event Browser. Each Compound Clip can then be an edited scene. Your master Project timeline can then have the Compound Clips (scenes) edited into them. No Copy and Paste needed in this case. You can even keyword tag the Compound Clips with the word “Scenes” and you now have a Keyword Collection (bin) of Scene sequences (Compound Clips).
    This is why Compound Clips are a bit more “interesting” than nests. While you can Compound Clips in a timeline, like a nest, You can also create Compound Clips in the Event Browser so you can have multiple sequences which you can then edit to a “master” Project Timeline.
  • Fredy Schwerdtner
    August 2, 2011 at 9:04 pm
    Thanks for the explanation. I will try that workflow.
    16 GB memory
    MacBook Pro 17″
    OWC RAID 5 with 3TB
    OS X 10.6.5
  • David Battistella
    August 3, 2011 at 3:08 pm
    This thread is worth a read and possibly sending feedback to Apple.
    https://forums.creativecow.net/readpost/344/2803
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://vimeo.com/battistella
