Editing an mp4 file using Isotope RX4
Posted by Larry Watts on October 27, 2015 at 6:56 pmOK, this may be dumb, but to be safe I better ask.
I’m going to fix some audio in an mp4 audio/video file. RX4 doesn’t handle video, so if I edit the audio and save it back out will the video still be attached and in sync?
Peter Groom replied 10 years, 11 months ago 3 Members · 3 Replies -
Ty Ford
October 28, 2015 at 3:21 amHello Larry and welcome to the Cow Audio Forum.
I think if you export your audio from the video, import it into the stand alone version of RX4, do what you want to do and then replace the original audio with the audio you processed in RX4, that should work. Try it off-line with something non-perishable first. I’m not aware that RX4 will let you edit audio. I think it just processes it.
Regards,
Ty Ford
Cow Audio Forum LeaderWant better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford’s Blog -
Peter Groom
October 28, 2015 at 11:34 amNo the audio will not be embedded / attached to the video anymore.
Best workflow.
1)Take video file with embedded audio into a video NLE such as AVID
2) export the audio track as wav or aiff
3) import into rx and work on it
4) render it back out with changes completed
5) import to avid and re lay on timeline
6) export timelineas a video again.NB If youre in pro tools you can re export the video track with a new audio track natively within pro tools
Peter
Post Production Dubbing Mixer
Peter Groom
October 28, 2015 at 11:36 amId add that using an mp4 isnt too hot an idea unless its all you have. Mp4s are really just a delivery file cos theyre small and transferable.
Best go back to an uncompressed file if poss / or a pro res original, do the work and then re create a new mp4 from that amended export.
PeterPost Production Dubbing Mixer
