Activity › Forums › Apple Final Cut Pro Legacy › editing an EDL on Excell?
  • editing an EDL on Excell?
    Posted by Marcosh on July 17, 2008 at 6:34 pm
    Hi there,
    I have to edit (correct in-points and out-points) of an edl I generated on FCP (the TC of the dv tape I received doesn’t match the Beta master’s TC).
    What’s the safest/ best way to manually enter/change an EDL and what file format should I save it on?
    Marcos H.
    Quad G5
    2GB RAM
    OS 10.4.7
    FCP 5.0.4
    AE 6.5
    Andreas Kiel replied 18 years, 2 months ago 4 Members · 5 Replies
  • Aaron Neitz
    July 17, 2008 at 7:55 pm
    This might work better:
    Modify the timecode of your quicktimes to match the Beta master. Assuming your timecode is offset by the same amount.
    Then you can make a new EDL and no need to hand fix the old EDL
  • Marcosh
    July 17, 2008 at 8:15 pm
    Aaron,
    I don’t think I can manually change the TC of the QT I have already captured in FCP.
    Can I?
    Quad G5
    2GB RAM
    OS 10.4.7
    FCP 5.0.4
    AE 6.5
  • Stace Carter
    July 17, 2008 at 9:02 pm
    1. Double-click clip to open in viewer,
    2. Choose Modify -> Timecode
    for more detail:
    https://proquest.safaribooksonline.com/032111583X/ch03lev1sec10
  • Marcosh
    July 17, 2008 at 9:17 pm
    Thanks, Stace!
    Quad G5
    2GB RAM
    OS 10.4.7
    FCP 5.0.4
    AE 6.5
  • Andreas Kiel
    July 18, 2008 at 5:01 pm
    Just for the records:
    “Modify Timecode” only works really for QT movies not for QT compatible movies or files – though FCP will store a record about the changes in the project where you did this changes and it probably will work.
    But using QT compatible movies or files with modified TC will show up with blank or different data when used within another project if the project where you modified the data is not open, this also may happen if you “Media Manage” the files or import them into another project which a different setup.
    As said this only valid for “QT compatible movies or files” compared to “QT movies” – so don’t worry too much, but keep it in mind.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
