Activity Forums Panasonic Cameras Editing After Capture from HVX 200
  • Editing After Capture from HVX 200
    Posted by Brad Froman on February 20, 2006 at 11:48 pm
    I’d like to know if anyone has a link to a workflow through FCP and the hardware needed to capture from the HVX 200, edit on FCP, then output. I have FCP 4.5 HD, but I am only set up to edit SD.
    I currently am on G5 dual 2.0 with Promax SATA 500 GB, Aja I/O. Do I need anything like a Kona 2? I know I would certainly need more drive space. What external drives on the market could handle the throughput necessary?
    Any direction would be greatly appreciated.
    Brad Froman replied 20 years, 7 months ago 4 Members · 8 Replies
  • 8 Replies
  • Noah Kadner
    February 21, 2006 at 12:30 am
    Well technically all you need is a Firewire cable. DVCPROHD over Firewire has been supported in FCP for nearly two years now using SATA, ATA, FW400 and FW800 drives(though 400’s are a bit dodgy for this esp capture). If you wanted to view back on an HD monitor you’d go back through the camera. It’s only if you wanted to view on an SD monitor where you’d need to get some extra hardware for the HD-SD downconvert but I’d recommend instead getting an HD monitor. They are pretty affordable these days compared to before.
    Noah
  • Brad Froman
    February 21, 2006 at 11:53 am
    Thanks for the info. I have a Sony PVM 20L5 monitor. I may have to look into getting the HD card to stick in it. However, the card retails for over nearly $3,000. But, I suppose it would be worth it for CRT monitoring.
  • Joslyn
    February 21, 2006 at 6:34 pm
    so noah,
    if i were to purchase a panasonic BT-LH1700W, i will be able to have realtime preview via fcp since this a hd monitor but as for the pvm14l5 or 20L5, an aja/decklink is needed to do this? thanks.
  • Noah Kadner
    February 21, 2006 at 8:07 pm
    Not quite sure what you mean there- the HVX can be used as a playthrough device to 720p/1080i compatible monitors. The AJA card could be used in its place as a playthrough or as an HD to SD downconvertor for non-HD monitors.
    Noah
  • Joslyn
    February 21, 2006 at 8:15 pm
    what i’m wondering is realtime previewing of hvx footage while editing in fcp, for example, the same way as done w/ dv editing where you have the camera hooked up via firewire from the mac and s-video out to the monitor showing you realtime previews while editing. except what i’m wondering is for dvcprohd footage w/ the hvx component outputs and into an hd monitor such as the panny mentioned above?
  • Noah Kadner
    February 21, 2006 at 9:54 pm
    That should be no problem.
    Noah
  • Lawrence Marshall
    February 22, 2006 at 12:42 pm
    Brad, you dont’ need the expensive HD board with the Sony 20L5 monitor. I have this monitor also… feed it analogue component from an HD source and it will switch over to display the HD signal.
    Larry M
  • Brad Froman
    February 22, 2006 at 1:15 pm
    Really! Then I wonder what the HD card actually does then.
