Activity Forums Adobe Premiere Pro Editing a video @ 36 fps
  • Editing a video @ 36 fps
    Posted by James Siv on June 26, 2014 at 7:16 pm
    A client gave me a video he recorded using a desktop recording software. Somehow he recorded at 36 fps which caused a 30 second audio gap. When I play it back trying to use 30 fps, I get weird stuttering which I thought would happen. The codec is Microsoft video 1, if that helps.
    Is there a way I can set Premiere to 36 fps so I can fix this audio? Or is there some other suggestion to fix the gap. Thanks!
    Marcin Grabos replied 12 years, 2 months ago 3 Members · 3 Replies
  • Chris Borjis
    June 26, 2014 at 11:13 pm
    [James Siv] ” is there some other suggestion to fix the gap”
    right click the clip and interpret the footage at 36 fps.
    you should then be able to put it in a 30 fps sequence and have it behave properly.
  • James Siv
    June 27, 2014 at 10:14 pm
    Thanks for the response, but unfortunately that didn’t work. Right click on the footage > Modify > Interpret Footage. Already selected under frame rate is “Use Frame Rate from File: 36.0000”. Select OK.
    Throw it down on my timeline and it still has the stuttering effect.
  • Marcin Grabos
    June 27, 2014 at 11:21 pm
    I’ve just recorded screen with sound using Microsoft Video 1 codec in 36 fps and wav, imported it to PProCS6 and everything is perfect in 36p sequence. Maybe you’ve installed codeck pack like k-lite which is messing with premiere’s a/v libraries. The easiest thing to do is to convert video from client to another format.
