Activity › Forums › Apple Final Cut Pro Legacy › Editing a time lapse
  • Editing a time lapse
    Posted by Jason Caridi on July 11, 2011 at 3:23 pm
    I took pictures of a sunrise every 5 seconds for 30 seconds and want to do the typical time lapse… where you crop part of it, and for each successive photograph, the crop mark moves a little too. This will ultimately be in Final Cut Pro, of course. What is a good tutorial for doing this? And what about doing more complex things like superimposing one crop of a picture across a crop of a different part of the picture, and still having the scene “move?” Or even making the succession a keyframed video clip, so the colors, etc., could change as the pictures progress?
    Thank you for any sort of help!
    Mark Suszko replied 15 years, 2 months ago 3 Members · 4 Replies
  • Chris Tompkins
    July 11, 2011 at 4:11 pm
    Why are you cropping?
    Why are the crops not the same on every frame?
    I would run ALL the stills through an automated process to:
    Open Image.
    Resize Image.
    Save As XXX.png.
    You can do this w/ PhotoShop or other batch image program.
    Then, open image sequence in QT7 and save it out as a prores mov file.
    OR
    Import stills into AE and render out a movie.
    OR
    Set your import stills duration in FCP to 1 frame.
    Import all stills.
    Drop in Sequence.
    Chris Tompkins
    Video Atlanta LLC
  • Jason Caridi
    July 11, 2011 at 4:18 pm
    I’m cropping because I shot 22MP and area-wise… only need about 1/10 of the frame, and on top of that I will be tilting up throughout this area I need. How do I do the batch process in Photoshop, and when I do, do I resize it to only contain the 1/10 of the image (in total, I guess I could do the motion in FCP?) that I need?
    Sorry if I’m confusing, I was up all night shooting the sunrise and shots at a New Jersey beach
  • Chris Tompkins
    July 11, 2011 at 4:31 pm
    Photoshop has a Automate batch option, you’ll have to look into it.
    Moving and cropping will make this more challenging for sure.
    I would resize to what you want to edit.
    1920X1080
    or whatever.
    Chris Tompkins
    Video Atlanta LLC
  • Mark Suszko
    July 11, 2011 at 9:32 pm
    Use tghe batch actions in photoshop, keepign the final frames huge/ original size and res, to get your time lapse.
    The either use QT pro to export the sequence of stills into one MOV file, or import the stills to a bin in FCP, with your perfercnes for stills duratino set at 1 frame, then drag and drop the contents of the folder to the timeline, render into a single mov file, and now, you have the ability to crop and add moves and filters and whatnot to the bae animated footage, easily and nondestructively.
