Activity Forums Apple Final Cut Pro Legacy editing a movie recorded in quicktime pro with final cut pro (frame rate issues)
  • editing a movie recorded in quicktime pro with final cut pro (frame rate issues)
    Posted by Andy Needle on September 16, 2008 at 2:01 pm
    hello
    I recorded a 5 minute clip using the isight on my macbook pro and quicktime pro movie recording. I want to edit that video on final cut pro. the problem i get is that when i drop the clip in the timeline on final cut pro the video is out of synch with the audio. It also plays at a faster speed. I looked at the frame rate it was recorded in and every clip i recorded using movie recording on quicktime pro had a different frame rate (around 20 frames but always different e.g 20.8 or 21.76) When importing this video into the timeline on fcp fcp told me that the sequence settings do not match the clip settings so that it would adjust them for me. I went inrto sequence settings and it had adjusted the sequence settings as 29.97 (which i think is the NSTC standard) this i suppose results in the faster video speed.
    The clip i recorded in movie recording on quicktime was the better setting in preferences (H.264) I also tried the device native setting that recorded it at 21.9. Neither synch up when i import them into fcp.
    Basically i just want to edit the video in final cut pro and have the video synch with the audio. I tried changing the frame rate in sequence settings so that it matched the clip but all the options were presets. I have tried to change the recording settings in quicktime but there seems to be no option to record at a cetrain frame rate.
    I really need someones help and quickly.
    Thanks a lot for reading this.
    Andy
    David Roth weiss replied 18 years ago 3 Members · 2 Replies
  • Chris Poisson
    September 16, 2008 at 3:59 pm
    Is there a reason you need to use footage from an MBP? Then edit in a professional app?
    Have a wonderful day.
  • David Roth weiss
    September 16, 2008 at 4:05 pm
    H.264 is not an editing codec. You have to create the file as DVD or transcode to DV before editing.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
