Activity Forums DaVinci Resolve Editing a feature in Divinci Resolve.
  • Editing a feature in Divinci Resolve.
    Posted by Matthew Kulvicki on August 30, 2024 at 8:24 pm
    Hello, I just finished production on a feature and I’m considering doing the edit in Divinci resolve. I have 2 back ups but I want to select a Raid that is decent to work off of (Maybe 40 terabytes of footage). I will likely need a new mac also, but want a reliable, fast raid to 1. create a new backup and 2. have all the footage in one place. Any recommendations for a raid would be greatly appreciated. Thank you. -Matt
    Glenn Sakatch replied 2 years ago 4 Members · 3 Replies
    August 30, 2024 at 11:51 pm
    Hey Matthew,
    40TB of footage – what is the data throughput per second?
    And, out of interest, what storage are you using for your back-ups (I expect that you keep them in separate locations?).
    Depending on budget and where the project goes afterwards, the easiest may be to look at the BlackMagic solution:
    https://www.blackmagicdesign.com/products/blackmagiccloudstore
    As it sounds like you are starting over with a new system, you should consider getting a turnkey system solution with support.
    Hope that this helps?
  • Tim Neighbors
    September 5, 2024 at 6:42 pm
    After a lot of research I ended up going with this JBOD from Qnap and did a Raid 5 (kinda wish I’d done a raid 6):
    https://www.amazon.com/gp/product/B086WCRFQ3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
  • Glenn Sakatch
    September 12, 2024 at 3:13 pm
    Tim, I’m just curious because I have one of those, but i honestly was under the impression that it would not work as a stand alone device. It is listed as an expansion enclosure. Mine is used as Raid #4 in my Qnap universe, but i thought it needed the main QNAP brain to work at all.
    Just curious if it is working for you as a stand alone device.
