Activity › Forums › Apple Final Cut Pro Legacy › Editing 60i footage
Editing 60i footage
Posted by Andy Morin on February 9, 2011 at 4:59 pmI’ve been shooting in 1920×1080 60i and when exported I’m getting the weird horizontal lines during fast movement. I solved the problem by using the de-interlace feature. My question is am I doing this correctly or am I completely nulling the effect 60i should have in the first place. Any techniques or recommendations?
Matt Campbell replied 15 years, 7 months ago 3 Members · 5 Replies -
Matt Campbell
February 9, 2011 at 5:12 pmThose lines are normal being that its 60i or 60 interlaced fields per second. Which is 29.97 frames per second. If for broadcast, this is normal to have interlaced fields. They are most visible on computer monitors. Are you viewing on an external broadcast monitor or TV? If so, they wouldn’t be that noticeable.
If using for web, you’ll want progressive, try de-linterlacing in Compressor turning on frame controls for smoother motion.
OS 10.6.3, Mac Pro 2 x 2.66 ghz quad-core intel xenon, 16 gb ram, with BM Intensity Pro card
Tony Silanskas
February 9, 2011 at 5:15 pmDepending on what your final output needs to be you could be doing it right. Depends on if you need to keep your footage interlaced or not. Is this for web, TV? Final specs?
tony
Andy Morin
February 9, 2011 at 5:21 pmThis is for the web and i was just viewing it on my mac monitor, so that might have been the error. So just de-interlacing should be fine then? If it’s for web only, should i even shoot in 60i or would i be better off on another setting?
Tony Silanskas
February 9, 2011 at 5:27 pm60i is fine for web as long as you deinterlace (in compressor preferably like Matt mentioned) the final file. Also depends on what “style” you’re going for (24p gives you a film look, 60i is a live TV look) Shooting with a progressive format would save you a step but if you want to keep the 1080 resolution and live TV look your workflow is fine.
tony
Matt Campbell
February 9, 2011 at 5:51 pmAs Tony suggests, it depends on your look. I’m always for shooting everything progresssive. Depending on what camera you use will help. I use the Panasonic HVX 200. And almost always shoot 720p24PN or 30PN because its a native progressive format and 30p is so easily converted to Interlaced if need be.
But again, you can totally de-interlace your 60i material after the fact.
