Activity Forums Apple Final Cut Pro Legacy Editing 50i 60i and 25p together
  • Editing 50i 60i and 25p together
    Posted by Fergal Cunningham on December 15, 2009 at 12:41 pm
    Hi all,
    I have a little bit of a problem. Editing a wedding video and unfortunately all the footage I have was shot at 50i, 25p and 60i. So I need to edit them all together, don’t really mind which format I end up in, as long as all the footage plays well together.
    I suppose converting the 60i to 25p or 50i would be best, and then editing in either 25p or 50i?
    I tried using natress, but it took quite a long time to render out, and time is an issue. Is there a quicker way to do it? And what are the best settings in Natress for converting 60i to either 25p or 50i, just to be sure I’m not doing something wrong.
    I appreciate any advice, thanks.
    Any advise would be greatly appreciated, thanks.
    Newton Niu replied 16 years, 8 months ago 3 Members · 3 Replies
  • Steve Eisen
    December 15, 2009 at 3:30 pm
    Choose one format to edit. I’ll assume you are working with HDV footage. You’ll need a lot of time and patience using HDV. If time is important, upgrading to a new Mac Pro with a fast RAID and plenty of RAM will speed things up.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Fergal Cunningham
    December 15, 2009 at 8:47 pm
    it’s going to be a PAL DVD and a HD mpeg2 file for playback on a PS3 (I’ll be going with compressor’s program stream preset).
    So I guess converted the 60i to 25p or 50i is the best option, any advice?
    It’s annoying really, there were 3 cameras set up, and one was on 60i when it should have been 50i.
    Any help much appreciated.
    Cheers.
  • Newton Niu
    December 16, 2009 at 1:01 am
    i don’t know~but good question~~hope someone can really answer it, instead of just writing some inessential things that we don’t need.
