Activity Forums Apple Final Cut Pro Legacy editing 2k in final cut pro
  • editing 2k in final cut pro
    Posted by Reece Farris on August 10, 2009 at 4:36 am
    I have transcoded my 4K red footage to 2k prores files (2048×1080) in redrushes and now want to edit 2K in fcp.
    How do I best set up my project for this? I guess first I need to know how to set up a timeline that can handle 2048×1080
    Feel free to ask for anymore info that is needed
    Cheers
    Ray Chung replied 17 years ago 2 Members · 1 Reply
  • Ray Chung
    August 10, 2009 at 11:54 pm
    You can look through the ‘Easy Setup’ menu when you start up and pick a Seq that matches what you’ve got…e.g. Apple ProRes 422 HQ 2048×1080. Or, pretty-much regardless of what you pick, if you have your media already on your drives and import then into your bin, then drop a shot onto a blank timeline, FCP should ask you if you want to adjust your sequence settings to match the format which you are trying to drop in there…to which you can choose ‘okay’.
