Activity Forums Apple Final Cut Pro Legacy editing 24p regular footage on 23.98 sequence
  • editing 24p regular footage on 23.98 sequence
    Posted by Joe Editor on December 8, 2006 at 1:20 am
    i shot a bunch of footage on 24p Advanced (with the dvx100a), and am editing on a 23.98 sequence.
    however, somehow on one of the tapes, it got switched to 24p regular mode. therefore the footage comes out 29.97.
    i tried to conform the footage to 23.98 using cinema tools but it looks pretty “stuttery” when i drop it into my 23.98 seq.
    am i in trouble, or is there any way to fix that?
    thanks so much for your help.
    Dom Silverio replied 19 years, 9 months ago 4 Members · 5 Replies
  • Jerry Hofmann
    December 8, 2006 at 1:56 am
    Did you really conform to 23.98 or 24 fps? If 24, you need to conform to 23.98 for sure… see page 212 of the cinema tools online manual… do exactly as they suggest there.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jerry Hofmann
    Jerry
  • Izoneguy
    December 8, 2006 at 3:03 am
    24p footage at 29.97 needs a “reverse tele-cine” not a conform.
    Try that and see if that works.
  • Dom Silverio
    December 8, 2006 at 5:43 am
    You are OK. You just need to bring the 24p Standard pulldown material to Cinema Tools to be pulldwon.
    FYI – 24p Advance and 24p Standard are both running at 23.976p with DVX100.
  • Dom Silverio
    December 8, 2006 at 5:46 am
    To add – removing pulldown from 24p Standard and 24p Advance will be result a 23.976p footage.
    You just can’t remove pulldown via firewire with 24p Standard with FCP. It has to be done with Cinema Tools.
