Activity Forums Canon Cameras Editing 16:9 DV
  • Editing 16:9 DV
    Posted by Pouyan Fard on April 2, 2008 at 3:48 pm
    Hello
    I just shot something with my Canon A1 in the DV 16:9 mode. When I bring the footage in Final Cut pro everthig is streached.
    How should I set my sequence so I can edit in 16:9 mode
    any help is appreciated
    thanks Pouyan
    Don Greening replied 18 years, 5 months ago 2 Members · 1 Reply
  • Don Greening
    April 2, 2008 at 5:58 pm
    If you shot in NTSC then use the DV NTSC Anamorphic sequence preset. If you shot in PAL then use the PAL Anamorphic sequence preset. Make sure the Anamorphic box is checked in the setup window.
    – Don
