Activity Forums VEGAS Pro Edited with Vegas.
  • Edited with Vegas.
    Posted by Steph St. laurent on April 18, 2005 at 10:14 pm
    Hi folks.
    I did a little commercial spot completely within Vegas and I’d love to have your feedback on it. The quicktime compression they use blurs it out a bit but it’s pretty much all there.
    Mine is number 10.
    https://rockthevotebc.ca/FPSE/index.php
    Thanks for supporting me over the last couple of years. I’ve learned so much from you folks, and I have so much more to learn. 🙂
    Stephen St. Laurent
    Steph St. laurent replied 21 years, 5 months ago 2 Members · 2 Replies
  • Sada
    April 18, 2005 at 10:53 pm
    Not bad–the cutting back and forth from Dave to the voice at the entry-way is disconcerting–you should just leave the camera on Dave. The movement through time with the white flash doesn’t work–try a slow transition—a dissolve is often used.
  • Steph St. laurent
    April 19, 2005 at 12:22 am
    Thank you Nancy. Good points. 🙂
    s.
