Activity › Forums › VEGAS Pro › Edited camcorder video from Vegas- crashes when skipping.
  • Edited camcorder video from Vegas- crashes when skipping.
    Posted by Julian Milano on February 25, 2013 at 11:41 am
    I’m using Vegas Pro 11 on Windows Ent x64. I copied the video from my camcorder (*.MTS) onto the PC, placed it in Vegas then Rendered it as “BluRay 1920×1080-50i, 10Mbs video” which resulted in the file Church.M2TS.
    The video plays nicely, however, if I skip ahead or behind, the first frame of the new destination shows and stays on the screen while the audio continues as normal. If I skip again, the same thing happens.
    Why would it be doing this?
    My aim is to produce a 1920×1080 video with 5.1 audio.
    Media Info:
    General
    Complete name : \hp-dv7d$Media[2012-09-15] Josh & Joey’s WeddingOutputChurch.m2ts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 11.4 GiB
    Duration : 1h 43mn
    Overall bit rate mode : Variable
    Overall bit rate : 15.8 Mbps
    Maximum Overall bit rate : 18.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=2, N=13
    Codec ID : 27
    Duration : 1h 42mn
    Bit rate mode : Variable
    Bit rate : 14.8 Mbps
    Maximum bit rate : 15.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.285
    Stream size : 10.6 GiB (92%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Format settings, Endianness : Big
    Codec ID : 129
    Duration : 1h 43mn
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : -40ms
    Stream size : 285 MiB (2%)
    This happens on VLC, WMP and my Xtreamer hardware media streamer/player.
    +– JDMils
    +– Sony Vegas V11
    +– Sony HDR-XR260VE
    Julian Milano replied 13 years, 7 months ago 2 Members · 2 Replies
  • Dave Osbun
    February 25, 2013 at 9:03 pm
    What type of computer hardware are you using?
    I help out a lot of people on the Tom’s Hardware message board, and most of those people that have video editing issues seem to all be using AMD processors. Unfortunately there really isn’t a worse cpu choice for video editing workstations than AMD.
    Oops…..guess i’m jumping the gun here…….
    Dave
  • Julian Milano
    February 26, 2013 at 8:03 am
    Thanks Dave. I’m using the following:
    [HP-DV7]
    Windows 8 x64 Enterprise SP1
    Intel i7, Q740 1.73GHz
    C: = 750GB, D: = 750GB
    It seems that it has something to do with the Format being BDAV. But I am struggling to find a codec in Vegas which will give me:
    1920 x 1080p
    50Hz
    5.1 Channel audio
    +– JDMils
    +– Sony Vegas V11
    +– Sony HDR-XR260VE
