Activity › Forums › Apple Final Cut Pro › Editable text
  • Editable text
    Posted by Al Flores on June 13, 2017 at 3:59 pm
    Hi guys! I’m having such a hard time with this, once you have your layers in PSD, once you’re in FCP… Can you edit the text in FCP or you need to go back to PSD and edit the text? Can’t you do it directly in FCP? Thanks by advance!
    Dave Jenkins replied 9 years, 3 months ago 3 Members · 3 Replies
  • Shane Ross
    June 13, 2017 at 7:11 pm
    No…the text is part of the PSD file. If done in PSD, it needs to be changed in PSD. Even FCX can’t dig into a PSD file and change the text.
    Sorry
    Shane
    Little Frog Post
  • Al Flores
    June 13, 2017 at 8:44 pm
    That’s very sad news Shane! I need to change hundreds of pieces and i wanted to build a master piece and changed it directly. Wow… Thank you!
  • Dave Jenkins
    June 14, 2017 at 5:03 am
    You should add your PSD to a Motion file without the text and use a Motion Title published to FCPx and the text can be changed in FCPx
    Dajen Productions, Santa Barbara, CA
    Mac Pro 3.5MHz 6-Core Late 2013
    FCP X
