Activity › Forums › Adobe After Effects › editable Illustrator text in after effects
Kevin Camp replied 5 years, 4 months ago 8 Members · 14 Replies
Andrew Jehan
May 19, 2021 at 12:03 amNo, but that’s just it. If you export to PSD in RGB mode, the editable text option is greyed out / not available.
Kevin Camp
May 20, 2021 at 9:03 pmFor me, if I switch the color mode of the file to RGB first from the file menu (File > Document Color Mode > RGB) the editable text is not greyed out when exporting to a PSD.
Andrew Jehan
May 21, 2021 at 2:37 amThen you must not be using layers. To get layers and editable text together you need to export in CMYK mode.
Kevin Camp
May 21, 2021 at 3:12 pmIt works on my system as long as I switch the color mode to RGB before trying to export.
I’m currently running Illustrator 25.2.1 on macOS 11.3.1, but I’ve done the same on earlier versions.
