Activity › Forums › Apple Final Cut Pro Legacy › Edit workflow when shooting 720p DVCPRO HD
  • Edit workflow when shooting 720p DVCPRO HD
    Posted by Timothy Eck on December 22, 2010 at 6:39 pm
    We have been an SD-only shop until very recently, but now we have the opportunity to produce some HD promotional spots. We will be shooting in DVCPRO HD 720p on P2 cards and importing into Final Cut Pro via Log and Transfer.
    Our understanding of DVCPRO HD is that the files we will be importing will be anamorphic (960×720 rather than 1280×720… and 1280×1080 rather than 1920×1080). Is this correct?
    If so, we are not sure where to go from there, workflow-wise… Do we work on an anamorphic (960×720) sequence? or a square-pixel sequence (1280×720)? What makes things confusing is we have AJA Kona LHe cards in our Macs… and the stock Final Cut Pro sequence preset for 720p59.94 seems to be anamorphic (960×720), while the AJA preset for 720p59.94 seems to be square pixel (1280×720).
    Furthermore, should we create graphic elements for editing these spots in anamorphic (960×720) or square pixel (1280×720)?
    We will be delivering the final product via Quicktime .MOV files and uploading them to our regional master control. What’s the best way to output the final product? DVCPRO HD encoded .MOV files at 960×720? or 1280×720? Is a square pixel Quicktime file even possible when outputting with the DVCPRO HD codec? From talking to one of our head-end engineers, the cable boxes with which our viewers receive the material output 1280×720 on their end.
    In review:
    FCP SEQUENCE: 960×720? or 1280×720?
    GRAPHICS: 960×720? or 1280×720?
    OUTPUT: 960×720? or 1280×720? codec?
    Thanks in advance…
    Walter Soyka replied 15 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Cody Walters
    December 22, 2010 at 7:39 pm
    Timothy,
    Your sequence settings will be…
    960×720 frame size
    Pixel Aspect Ratio: HD (960×720)
    Really all you need to do is create a new sequence, add your video and final cut will automatically set the right settings for you.
    I believe that you need to match your sequence settings for your graphics as well. Make sure same frame size and aspect ratio.
    When you export, export with current settings. You will see that once exported, the video is now at 1280×720.
    Cody Walters
    Mac Pro 2.26GHz 8 Core Xeon
    16 GB 1066 MHz DDR3
    Final Cut Studio 3
    Panasonic HVX-200
  • Walter Soyka
    December 22, 2010 at 9:59 pm
    [Timothy Eck] “FCP SEQUENCE: 960×720? or 1280×720?
    OUTPUT: 960×720? or 1280×720? codec?”
    I’d prefer to produce the graphics at 1280×720 (square pixels) and edit in FCP in a 1280×720@59.94p ProRes sequence — why throw away 25% of the horizontal resolution on your graphics to keep everything in thin-raster DVCPRO HD? Then again, I run a graphics shop, so surely I’m biased.
    What are your deliverable requirements? Different broadcasters will have different requirements depending on their playout systems, and it may be a consideration in designing your workflow.
    Walter Soyka
  • Timothy Eck
    December 31, 2010 at 7:22 pm
    I agree Walter. The specs for delivery only specify 720p at 59.94. Nothing is specified about the horizontal aspect however. I made inquiries about delivering with the DVCPRO HD codec and they confirmed we can submit with it. When I inquired about the horizontal aspect question, they didn’t seem to know or understand the difference.
    I think before I press them further, I still need to confirm or deny whether the DVCPRO HD codec will even allow 1280×720 square pixels… or whether it FORCES 960×720 anamorphic.
  • Walter Soyka
    December 31, 2010 at 7:32 pm
    [Timothy Eck] “I think before I press them further, I still need to confirm or deny whether the DVCPRO HD codec will even allow 1280×720 square pixels… or whether it FORCES 960×720 anamorphic.”
    DVCPRO HD is a thin-raster format. It doesn’t do square pixels.
    Walter Soyka
  • Walter Biscardi
    January 1, 2011 at 2:55 pm
    [Timothy Eck] ”
    Our understanding of DVCPRO HD is that the files we will be importing will be anamorphic (960×720 rather than 1280×720… and 1280×1080 rather than 1920×1080). Is this correct?”
    Yes. But for 1080 it will be 1280 x 1080 for NTSC and 1440 x 1080 for PAL.
    [Timothy Eck] “If so, we are not sure where to go from there, workflow-wise… Do we work on an anamorphic (960×720) sequence? or a square-pixel sequence (1280×720)? What makes things confusing is we have AJA Kona LHe cards in our Macs… and the stock Final Cut Pro sequence preset for 720p59.94 seems to be anamorphic (960×720), while the AJA preset for 720p59.94 seems to be square pixel (1280×720).”
    You simply set up a standard DVCPro HD 720 / 59.94 timeline. Just use the AJA Kona Easy Setup. As DVCPro HD is an anamorphic format, the Kona is setting you up correctly.
    [Timothy Eck] “Furthermore, should we create graphic elements for editing these spots in anamorphic (960×720) or square pixel (1280×720)?”
    I create the graphics in 1280 x 720 and then squeeze them horizontally for DVCPro HD timelines.
    [Timothy Eck] “We will be delivering the final product via Quicktime .MOV files and uploading them to our regional master control.”
    Ah, well then this changes things. What you want to do in this case is edit in a ProRes 720p timeline. This is a full raster, square pixel format and you will edit in a full resolution 1280 x 720 timeline. You will need to render your DVCPro HD clips when you’re done, but everything will be in square pixel, full 1280 x 720 frame when you export a quicktime movie.
    That will be the easiest for someone who is starting out in HD. I’m not sure if the Log and Transfer Tool can change the clips from DVCPro HD to ProRes yet. I know it does for AVC-Intra codec, but not sure for DVCPro HD.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” Winner, Best Documentary, LA Reel Film Festival.
    Blog Twitter Facebook
  • Timothy Eck
    January 12, 2011 at 2:54 am
    In my first test, I worked off a 1280×720 square pixel timeline, and exported to Compressor. I outputted using a DVCPROHD 720p60 preset that I edited to be 1280×720 square pixels (instead of 960×720 anamorphic pixels). But the resulting .MOV file seems to still be 960×720 anamorphic pixels.
    Is the codec itself forcing the horizontal downsampling? Is 960×720 the only resolution the codec is able to produce?
    Is there another delivery codec someone can recommend that can do 1280×720 square pixels?
  • Walter Soyka
    January 13, 2011 at 8:12 pm
    [Timothy Eck] “Is the codec itself forcing the horizontal downsampling? Is 960×720 the only resolution the codec is able to produce?”
    Yes. DVCPRO HD is thin-raster only. If you were to somehow produce a square pixel, full raster DVCPRO HD-encoded file, you’d have no guarantees that the recipient would be able to properly decode it.
    [Timothy Eck] “Is there another delivery codec someone can recommend that can do 1280×720 square pixels?”
    Uncompressed, ProRes, DNxHD, Canopus HQ, MPEG2, MPEG4, H.264 — different systems have different specifications.
    Unfortunately, we can only give you theoretical guidance. Specific information on acceptable deliverables should come from whomever you’re delivering to. If they don’t know, they should get their engineers involved in the discussion.
    Walter Soyka
