Activity Forums Avid Media Composer Edit with video purchased through iTunes
  • Edit with video purchased through iTunes
    Posted by Andrew Thompson on March 19, 2013 at 4:05 am
    Im trying to edit a video purchased through itunes store and have hit a brick wall. It won’t import directly, quicktime won’t record it and neither will SNAPZ Pro. Does anyone know how to break through this problem?
    Andrew Thompson replied 13 years, 6 months ago 4 Members · 6 Replies
  • James Patterson
    March 19, 2013 at 9:47 am
    What format is it? If you need to convert it to be avid friendly try mpegstreamclip . It’s free and works on mac and windows
    Best
    Paddy
  • Michael Phillips
    March 19, 2013 at 1:58 pm
    It’s a DRM issue. Same thing used to happen with songs purchased through iTunes – importing via QuickTime saw the DRM and refused to process – same thing for video I suspect.
    Michael
  • James Patterson
    March 19, 2013 at 2:41 pm
    Ah, the old DRM! I thought I read somewhere that apple had stopped using DRM on itunes? I don’t tend to buy anything from itunes but it’s good to have a heads up if the need ever arises!
    Best
    Paddy
  • Michael Phillips
    March 19, 2013 at 2:51 pm
    They stopped it on music, not video… that’s a whole different negotiation with the studios. I don’t see that going away any time soon.
    Michael
  • Bryan Roberts
    March 21, 2013 at 3:35 am
    A quick google search should give you results on how to defeat it, I’ve had to do it a few times with an item I’ve purchased. I believe Lifehacker had the article? I think…
    FCP / AVID EDITOR
    Features : Television
    http://www.DefiningFilms.com
  • Andrew Thompson
    March 21, 2013 at 5:17 am
    Sadly I lost my battle with the DRM … I ended up getting the episode in a torent. So much for doing the right thing.
