Activity Forums DaVinci Resolve Edit with DaVinci 11 & Multicam
  • Edit with DaVinci 11 & Multicam
    Posted by Isaac Bergada on September 5, 2014 at 10:57 am
    Got a quick question regarding Resolve 11 and Multicam. Once imported a fcpxml I lose the angles inactives, leaving only one active clip. Has anyone found a solution to keep the others angles? Any help is greatly appreciated.
    Isaac Bergada replied 12 years ago 2 Members · 3 Replies
  • Theo Miesner
    September 7, 2014 at 7:10 pm
    Hey there Isaac! I’ve had that same issue. Luckily the fix is pretty simple. In your NLE (I am going to use Premiere Pro as an example) select all of your multicam sequence then right click > multicam > flatten. Re export your XML and you should be golden!
    shameless plug: If you want more sweet Resolve tips be sure to check out my youtube channel https://www.youtube.com/channel/UC_4HXushRwS_9b1JdRFYVgw
    Hope that this solves it for you,
    Theo
  • Isaac Bergada
    September 8, 2014 at 8:40 am
    Thanks Theodore, both FCP7 XML as FCPX XML will automatically make the collapse of video tracks.
    Because I’m looking for just the opposite. To keep all the video tracks when import XML to Davinci.
  • Isaac Bergada
    September 19, 2014 at 10:08 am
    Hi guys, excited to try the new version DaVinci Resolve 11.1 Beta ( with multicam support) :
    https://www.blackmagicdesign.com/support/download/15010/Mac%20OS%20X
