Activity › Forums › Apple Final Cut Pro Legacy › Edit videos with different Aspect ratios in final cut pro 7
  • Edit videos with different Aspect ratios in final cut pro 7
    Posted by Badr Dahi on August 18, 2013 at 4:23 am
    Hello,
    I Editing my new Documentary film and there’s some material that i downloaded with Different Aspect Ratios but most of my material shoot with canon 550D (1920×1080) my question is can i edit all videos in the same sequence and don’t get the square look 4:3 , or what is the best way to make my cuts between the 4:3 videos and 16:9 smooth and not jump-cuts ?
    Badr Dahi replied 13 years, 1 month ago 2 Members · 2 Replies
  • Shane Ross
    August 18, 2013 at 7:53 pm
    If you are editing SD, then I suggest sticking full screen (4:3) and any 16:9 footage you’ll have to manually “Pan & scan.” If you are working in HD, then you need to blow up the 4:3 footage to fill the screen (this will chop off the top and bottom) and again, manually pan & scan and frame each video, shot by shot.
    Shane
    Little Frog Post
  • Badr Dahi
    August 24, 2013 at 6:18 pm
    Thank you very much Shane
