Activity Forums VEGAS Pro Edit Video on TV?
  • Edit Video on TV?
    Posted by Paul Gregory on August 8, 2016 at 5:03 am
    I recall reading many years back several reasons why you should always use a monitor upon which to edit video. I the reason given were about things like color matching.
    Current TV’s all come with HDMI input with which to connect to a TV. An ever increasing number of TV’s are now 4K. Are the reason nowadays still just as valid?
    Thanks in advance
    Steve Rhoden replied 10 years, 1 month ago 3 Members · 2 Replies
  • John Rofrano
    August 8, 2016 at 6:25 pm
    [Paul Gregory] “Current TV’s all come with HDMI input with which to connect to a TV. An ever increasing number of TV’s are now 4K. Are the reason nowadays still just as valid?”
    Nothing has changed in the TV industry as far as color matching goes. If you buy 5 different HD or 4K TV’s from 5 different manufacturers and put them side-by-side and feed them the same signal I will guarantee you that no two TV’s will look the same. TV manufacturers pride themselves on the cleaver ways the employ to make blacker blacks and truer colors. No one cares if they actually represent the real image or not.
    This is why you always want to color correct on a hardware calibrated broadcast monitor and not a TV.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Steve Rhoden
    August 8, 2016 at 11:27 pm
    Nothing’s changed Paul. Still recommended you use a broadcast monitor for accurate colors.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
