Activity › Forums › Apple Final Cut Pro › Edit using Proxy, export using Optimised
  • Edit using Proxy, export using Optimised
    Posted by Robert Marsh on March 25, 2012 at 6:22 am
    Final Cut Pro X is constantly suggesting I use proxy footage because my hard drive isn’t fast enough. I want to know if I can edit the project using proxy footage but then export the final product, substituting the proxy footage for the optimised footage? Does the project make references to the optimised footage as you work with the proxy footage? What else can I do to speed up FCPX?
    Kevin Johnson replied 14 years, 6 months ago 2 Members · 1 Reply
  • Kevin Johnson
    March 26, 2012 at 1:52 am
    Select all of your footage, right click, and choose create proxy media (make sure proxy media is enabled in preferences). Editing/playback will always use proxy media, when you export it will use full res.
    Kevin Johnson
    Autodesk Smoke Artist
    FCP Editor
    Washington, DC
