Activity Forums Apple Final Cut Pro Legacy Edit to Video
  • Posted by Jason Jenkins on October 19, 2006 at 9:10 pm
    I’ve got FCP 5.2 here, hooked up to a UVW-1800 Beta SP deck. I am trying to figure out if there is a way to edit to tape with bars, slate, black, timecode, etc… without striping the tape first. I’ve got a bunch of dubs to make and it would be great if I could skip a step!
    Shane Ross replied 19 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Bouncing Account needs new email address
    October 19, 2006 at 9:52 pm
    Just put all of these things on the Timeline (part of your edit) and then just hit RECORD on the deck and PLAY the timeline.
    I do this with all my commercial dubs.
    You can set the TC on the 1800 to 00:00:00 (or any other number you like) before you record.
    The other thing you can do is just “stripe” the tapes for 30 seconds or so, then ASSEMBLE-edit from FCP during the area that is striped.
  • Jason Jenkins
    October 19, 2006 at 10:16 pm
    [Matte] “Just put all of these things on the Timeline (part of your edit) and then just hit RECORD on the deck and PLAY the timeline.
    The other thing you can do is just “stripe” the tapes for 30 seconds or so, then ASSEMBLE-edit from FCP during the area that is striped.”
    I need the program to start at exactly 01:00:00:00
    October 19, 2006 at 11:23 pm
    [Jason Jenkins] “I need the program to start at exactly 01:00:00:00”
    OK, that’s why I offered two options.
    Do the second idea I suggested and Assemble Edit “back-timed” so that the PROGRAM material begins at 1:00:00:00.
  • Jason Jenkins
    October 19, 2006 at 11:51 pm
    [Matte] “Do the second idea I suggested and Assemble Edit “back-timed” so that the PROGRAM material begins at 1:00:00:00.”
    Can I do that without striping the tape? It works fine when I stripe the tape but when I try without I get “end of tape” or “no timecode” errors. I was hoping to avoid the step of striping the tape.
    October 20, 2006 at 4:25 am
    [Jason Jenkins] “Can I do that without striping the tape?”
    Yes, that’s why I suggested it.
    Again, you must use “ASSEMBLE” mode (not “Insert” mode.)
    Assemble also records timecode and control track on the tape along with your audio & video material.
  • Jason Jenkins
    October 21, 2006 at 3:14 am
    I must have a setting wrong somewhere because it won’t work for me. It works fine if I stripe the tape first.
  • Shane Ross
    October 21, 2006 at 3:38 am
    I cannot see how you can do this without striping at least the first couple minutes of tape. That is what I do, stripe a tape just past the 1:00:00:00 mark (from 58:00:00) and then Assemble Edit.
    I cannot see how you can do this at all accurately without striping the tape at least a little bit.
    Shane
    Littlefrog Post
    http://www.lfhd.net
