Activity › Forums › AJA Video Systems › edit to tape/record isseue
  • edit to tape/record isseue
    Posted by Mike Varga on February 3, 2009 at 2:00 pm
    I’m definitely scratching my head here…
    using -MacPro, dual quad 3.2, 10 gb ram
    -AJA io’hd
    -Sony HDW-1800 HDCAM recorder.
    When i crash record and play from the timeline, eveything is groovy but,
    when i use edit to tape(assemble edit), the record tape records digital artifacts(small different colored blocks, and the condition light goes orange and red.
    I can’t do a final output (timecode sensitive), and i’m stuck
    Please help
    Thank You,
    MIke
    Mike Varga replied 17 years, 7 months ago 1 Member · 2 Replies
  • Mike Varga
    February 3, 2009 at 5:39 pm
    i saw a post by the infamous Bob Zelin saying to switch menu option 309 from auto 1 to auto 2, on a 2000 series deck, i did it to my hdw-1800 deck and what do you know…problem appears to be remedied. Thanks Bob wherever you are.
    Does anyone know what that menu option does or have any ideas of anything else that could trigger that problem?
    Best,
    Mike V
  • Mike Varga
    February 3, 2009 at 8:58 pm
    I found this in the manual.
    309 SERVO/AV REFERENCE
    SEL Select the servo reference signal.
    AUTO1: During recording, the input video signal is used as the servo reference
    signal. During playback, the signal selected by F2 (REF VID) in function menu
    page P03: VID PROC is used as the servo reference signal. If the signal
    selected by the F2 (REF VID) in function menu page P03: VID PROC is not
    connected, an internal reference signal is used.
    AUTO2: When F2 (REF VID) in function menu page P03: VID PROC is set to
    “REF”, and any of F2 (INS TC), F3 (INS CUE), and F5 (ASSEMBLE) to F10
    (INS A4) in function menu page P07: E.PRESET is lit, the reference signal for
    video/audio signal processing is locked to the input video signal.
    EXT: The servo reference signal is forced to be “EXT” (an external reference video
    input signal is used).
