Activity Forums AJA Video Systems Edit to Tape/Kona/FCP
  • Edit to Tape/Kona/FCP
    Posted by Robbie Socks on July 2, 2008 at 11:28 pm
    So i’m trying to EET from an Apple Pro Res Sequence in FCP 6.0.3 (i’ve also tried this in 8/10 bit without success) to an HD Cam tape (Sony HDW M2000 Deck set to 59.94).
    My Kona Card outputs are is set for 1080i @29.97 (which is 59.94 i think).
    I have “Printed to Tape” with success, however when i try and use EET the video looks all green and funky.
    I have used the Easy set up to set up my output, and I have made sure my kona setting look good, but there are so many options in the kona control panal i don’t know if i’ve selected all the right settings.
    Help…this has got to work.
    thank you.
    Robbie
    David Brier replied 18 years, 2 months ago 2 Members · 1 Reply
  • David Brier
    July 7, 2008 at 2:36 pm
    You need to check what video is feeding back into your system. I loop the deck signal back to my box, so that the card can lock onto the same signal that I am lying off to (and that jive with my easy set-up). More than likely, that’s the culprit, and not your easy set-up. Hope this help comes in time!
    David Brier | Post-Op Media
