Activity Forums Apple Final Cut Pro Legacy Edit To Tape Woes
  • Edit To Tape Woes
    Posted by Paul Turlick on June 1, 2005 at 4:36 pm
    Hi-
    For some unknown reason (it’s worked before with this setup) I can’t seem to get my
    code straight in edit to tape. The show starts at
    00:58:45:00 I black the tape from TC 00:58:00:00. I
    then type in 00:58:45:00 in the lower left hand box in
    the ETT window, drag the sequence onto the assemble
    button and hit enter. It then fast forwards the tape to 00:58:42:00 (3 secs of preroll) What’s happening is the show is
    starting at 00:58:45:00 but there is :45 seconds of
    black before it. As you could guess I need it to start
    at 00:58:45:00 with bars and not :45 of black
    preceding it. I have the Rec Mode of the deck set to
    tape rather than INT as in INT I can’t even get it to
    lock at all. I’ve tried in both “Mastering” and
    Editing” and still no luck. Am I doing something
    stupid again?
    Tracy replied 21 years, 3 months ago 3 Members · 3 Replies
  • Michael Belanger
    June 1, 2005 at 4:47 pm
    Sounds like the edit to tape option is set to Mastering not Edit . Check it out.
    Mike Belanger
    Dandelion Editing
    wwww.dandelionediting.com
  • Paul Turlick
    June 1, 2005 at 4:51 pm
    Unfortunately I’m in Edit mode.
  • Tracy
    June 1, 2005 at 7:29 pm
    When I black a tape, I usually start the black 5 sec before I want it to record… in your case start the black at 00:58:40;00.. just a thought.
    Tracy
