Activity › Forums › Blackmagic Design › edit to tape with HDW-D1800
  • edit to tape with HDW-D1800
    Posted by John Barnard on December 11, 2007 at 9:32 pm
    I can’t seem to layback using my multibridge. The process appears to go fine, but all that gets recorded on the tape is green digital blocks (with some remenents of picture), plus an intact soundtrack.
    THe deck records fine from the multbridge SDI using a simple crash edit, but from the “edit to tape window” – no dice.
    I must have some settings wrong?
    Blackmagic Multibridge
    Final Cut 6
    Mac Pro
    Model Identifier: MacPro1,1
    Processor Name: Dual-Core Intel Xeon
    Processor Speed: 3 GHz
    L2 Cache (per processor): 4 MB
    Memory: 3 GB
    Bus Speed: 1.33 GHz
    John Barnard replied 18 years, 9 months ago 2 Members · 4 Replies
  • John Barnard
    December 11, 2007 at 9:55 pm
    Could it be that I’m trying to output a prores 59.94 movie and the prores 29.97 video output is not compatible with the deck?
    Final Cut 6
    Mac Pro
    Memory: 3 GB
    Bus Speed: 1.33 GHz
  • John Barnard
    December 11, 2007 at 10:08 pm
    I managed to record the sequence to tape using a crash edit, so it must be some problem with the edit to tape window..
    Final Cut 6
    Mac Pro
    Memory: 3 GB
    Bus Speed: 1.33 GHz
  • Baz Leffler
    December 11, 2007 at 11:13 pm
    Hey John – I edit to tape all the time with my Multibridge Extreme and HDW1800. The trick is to make sure the reference is selected to ‘input’ NOT REFERENCE; otherwise you will get exactly what you are getting.
    Baz
  • John Barnard
    December 11, 2007 at 11:37 pm
    Yes Dammit!!! That was it! So much stress for one little button.. THANK YOU!!!
    Final Cut 6
    Mac Pro
    Memory: 3 GB
    Bus Speed: 1.33 GHz
