Activity › Forums › Apple Final Cut Pro Legacy › edit to tape window wont open
  • edit to tape window wont open
    Posted by Cara Holmes on November 6, 2008 at 1:32 pm
    Hi, I have been working on Final Cut 6 and when I go to play to tape the EDIT TO TAPE window wont expand out at all. Even with dragging at bottom and side it wont expand open.
    I can see the three tabs at the top but nothing else, can anyone help with this please?
    Everything else is working well
    Michael Gissing replied 17 years, 10 months ago 2 Members · 1 Reply
  • Michael Gissing
    November 6, 2008 at 9:08 pm
    Without info on your sequence settings and what you are trying to output to and with, etc it is hard to know, but I have seen that happen when the sequence settings don’t have an output codec.
    I would suggest re checking your easy setup and if necessary, checking the output codecs in the sequence settings.
