Activity Forums Blackmagic Design Edit to Tape Window in Premiere CC 2014 with UltraStudio 4k
  • Edit to Tape Window in Premiere CC 2014 with UltraStudio 4k
    Posted by Jordan Mena on June 18, 2015 at 6:33 pm
    When I lay back to HDCAM SR deck using Ultra Studio 4k. The edit to tape window timecode doesn’t match the Deck. The layoff is correct and frame accurate but it would be nice that the time codes in the edit to tape window match the deck.
    It worked correctly using Aja IO4k but since we switched its no longer correct.
    Is this a bug or a setting?
    Thanks, J
    Jordan Mena | Editor | Colorist | Producer
    Los Angeles, CA
    jordanmena.com
    Jordan Mena replied 11 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
