Activity › Forums › Apple Final Cut Pro Legacy › Edit To Tape w/ AJ-1400
  • Edit To Tape w/ AJ-1400
    Posted by Justin Toops on April 30, 2008 at 12:38 pm
    Hello everyone –
    This is our first time laying back a project to tape w/ our AJ-1400 deck… and we’ve been having an impossible time. Can anyone give me the step by step process?
    We have a DVPRO 720p60 timeline and want to go the same out to tape. The deck is connected to the computer HDSDI via a Kona3 (I am monitoring HDSDI out Panasonic LH2600W). Right now, I get audio just fine, but no picture.
    Initially, I set up to record TC to the tape. I used TC preset, set it to 00:58:30:00, hit record, and nothing happened. Can anyone walk a dummy though this process?
    -Toops
    Justin
    Editor/Chess Player, Washington DC
    2×3 GHz Intel Mac, 4 gigs RAM
    FCP 6, DVDSP4, Motion3
    KONA 3 capture
    Justin Toops replied 18 years, 5 months ago 3 Members · 10 Replies
  • 10 Replies
  • Walter Biscardi
    April 30, 2008 at 12:48 pm
    [Justin Toops] “Right now, I get audio just fine, but no picture.”
    What is your video input set to? Audio and video are two different settings.
    Also, what’s your Easy Setup? It should be AJA Kona 3 720/59.94 DVCPro HD.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Justin Toops
    April 30, 2008 at 1:06 pm
    Easy Setup is set to DVCPROHD 720p/59.94.
    Video (on deck) is set to HDSDI.
    The preview monitor shows a constant refreshing green flicker / flash. No picture… only audio.
    Justin
    KONA 3 capture
  • Walter Biscardi
    April 30, 2008 at 1:13 pm
    [Justin Toops] “Easy Setup is set to DVCPROHD 720p/59.94.”
    Wrong. You said you have an AJA Kona 3. The correct Easy Setup is the one I said in my first post. AJA Kona 3 720p/59.94 DVCPro HD. If you just have the regular DVCPro HD easy setup, you’re not using the Kona 3.
    Read my Blog!
  • Justin Toops
    April 30, 2008 at 1:19 pm
    Correction: the easy setup is Aja Kona 3: DVCPROHD 720p/59.94. Still no video, just green flicker.
    If anything, I should be able to record time code, right? Yet that it just pauses after I hit record.
    Appreciate your help.
    -Toops
    Justin
    KONA 3 capture
  • Walter Biscardi
    April 30, 2008 at 1:29 pm
    Is your deck properly set up for 720p/59.94? Or is it showing 1080i on the front panel?
    Read my Blog!
  • Justin Toops
    April 30, 2008 at 1:37 pm
    You’re right – it’s showing 1080i. I’m assuming now that I’ve got to dive through the menus to change it to 720p?
    Justin
    KONA 3 capture
  • Walter Biscardi
    April 30, 2008 at 1:50 pm
    [Justin Toops] “You’re right – it’s showing 1080i. I’m assuming now that I’ve got to dive through the menus to change it to 720p?”
    Yes, get the manual out or look at the Super Output. It’s something like menu 24 or 25 I think. System Format: 1080
    Read my Blog!
  • Justin Toops
    April 30, 2008 at 2:12 pm
    Got it – thanks walter!
    Changed the Sys Format to 720p… picture shows up great on the monitor. We’re in business.
    Last q: I still can’t lay black/TC to this tape. I’ve set the timeline on some slug, used the TC preset on the deck to set 00:58:30:00… hit record, and get nothing. The red record button stays lit up, but the time code doesn’t start recording. Is there another switch I need to hit to record some simple TC?
    Justin
    KONA 3 capture
  • Matt Larson
    April 30, 2008 at 3:04 pm
    Have you tried using the black and code buton in the ETT window? Set the deck to TCG REGEN and then try to black the tape from FCP. You set the TC Start time and DF or NDF in FCP.
    You can either black the whole tape and then insert audio and video, or if you are in a hurry, black the first minute or so, rewind the tape and ETT using Assemble. The deck will REGEN where your Assemble begins (assuming you have TC where the edit starts and the deck is set to REGEN)
  • Justin Toops
    April 30, 2008 at 4:26 pm
    Worked Awesome. I didn’t even know that button was there in ETT. Thanks!
    -Toops
    Justin
    KONA 3 capture
