Activity Forums Apple Final Cut Pro Legacy Edit to Tape Problems
  • Edit to Tape Problems
    Posted by Kay Nender on October 23, 2007 at 5:48 pm
    I’m running FCP 6 on a macbook pro, 2 gig intel core duo.
    I’m using media on drives connected to a firewire adapter in the P2 card slot. My DVCPRO 50 deck is connected firewire directly.
    When I capture and play out, I see all frames properly on my external monitor. When I try to use edit to tape, I do not get video or audio out.
    Deck settings are correct.
    Anyone recognize this problem? Thoughts?
    Russell Lasson replied 18 years, 10 months ago 2 Members · 1 Reply
  • Russell Lasson
    October 23, 2007 at 9:54 pm
    If you disconnect everything (firewire drives/P2 adapter) does it work?
    Have you ever had it working?
    You could double check your settings by using the easy setup. You could also try to delete your preferences.
    Good luck!
    -Russ
