Activity Forums Apple Final Cut Pro Legacy Edit to Tape off by approx 10 seconds
  • Edit to Tape off by approx 10 seconds
    Posted by Greg Nicholson on February 15, 2011 at 2:12 am
    OSX 10.6.4
    2.66 GHz Quad Core Intel Xeon
    8 GB 1066 MHz DDR3
    FCP 7.0.2
    Blackmagicdesign I/O Decklink HD Extreme 3D
    SDI
    AES
    9 pin deck control
    Sony HDCAM Deck HDW-500
    Sequence Settings
    1920x1080i
    Pixel Aspect Ratio Square
    Field Dom Upper
    Edit Timebase 29.97
    Compressor Apple ProRes 422
    DF
    Problem: TC on FCP sequence does not layback to tape with audio and video. I’ve blacked my master tape using DF starting at 00:58:50;00. I’ve tried LTC only, VITC only and “Auto” My video with bars starts at 00:59:08;02 with the program starting at 01:00:00;00. Everything seems to get shifted forward approx ten seconds to early on the tape. (ie Rather than main program starting at 01:00:00;00 it starts at 00:59:49;00 approx)
    My IN point on the Edit to Tape window reflects the exact IN point in the sequence. I have an OUT point in the sequence as well.
    I’ve never had this problem when laying off HD projects to the HDCAM deck when handling NDF HD footage. So I’m thinking this problem is related to DF.
    Thoughts anyone? I’ll try to respond quickly with any questions or clarifications. Thanks so much!
    John Heagy replied 15 years, 6 months ago 5 Members · 16 Replies
  • 16 Replies
  • Jeremy Garchow
    February 15, 2011 at 3:44 am
    Are you dragging your sequence from the browser to the “assemble” overlay of the ETT window?
    Are you laying off the whole sequence? If so you don’t need in and out points on your sequence, you just need to set the in point you want to start on the tape to the in point of the ett window.
    Are you using the proper easy setup that matches your footage/timeline/frame rate?
  • Greg Nicholson
    February 15, 2011 at 2:01 pm
    I drop my sequence in the Viewer window and I click the Assemble button in the ETT window.
    Yes, I’m laying off the entire sequence. I will try removing the OUT point from my seq. and respond promptly with whether that worked.
    Clip info:
    MPEG-4 (Quicktime)
    138 Mbps 1920*1080 (16×9) at 29.97 fps
    Sequence settings:
    See Above
    Audio/Video Settings
    Video Playback: Blackmagic HD 1080i 59.94 – 8 bit 1920×1080
    OSX 10.6.4
    8 GB 1066 MHz DDR3
    FCP 7.0.2
    SDI
    AES
    9 pin deck control
  • Jeremy Garchow
    February 15, 2011 at 2:06 pm
    Bingo. Can’t layoff an mpeg4 file in Fcp. Convert the file to an Fcp friendly edit codec (prores et al) and I’m sure you’ll have less problems.
    Also you should drag the sequence from the browser to the ETT assemble overlay once you get your timeline conformed to a better codec.
  • Greg Nicholson
    February 15, 2011 at 2:29 pm
    I hope it’s as easy as that… but when I drop the clip in the timeline and FCP asks if I want to change the seq settings to match the clip, I say Yes and the sequence codec settings change to ProRes 422.
    The MPEG-4 information I got from a little program called Media Info that can look at clips and tell the user info on the clip. I’m not sure how accurate it is because the guy I got the clip from told me it was ProRes and FCP’s behavior seem to reflect that.
    thoughts?
    thanks.
    OSX 10.6.4
    8 GB 1066 MHz DDR3
    FCP 7.0.2
    SDI
    AES
    9 pin deck control
  • Greg Nicholson
    February 15, 2011 at 2:35 pm
    The Item Properties in FCP tell me the clip is: Compressor: Apple ProRes 422 Vid Rate 29.97
    Since my output is 59.97 is the frame rate the issue? Even though I have a 1080i59.97 seq and output, the sequence still says 29.97 Edit Timebase. This confuses me…
    OSX 10.6.4
    8 GB 1066 MHz DDR3
    FCP 7.0.2
    SDI
    AES
    9 pin deck control
  • Greg Nicholson
    February 15, 2011 at 3:06 pm
    oh, because 1080i59.94 is actually 60 FIELDS (approx) and the frame rate is still 30 (approx)
    correct?
    OSX 10.6.4
    8 GB 1066 MHz DDR3
    FCP 7.0.2
    SDI
    AES
    9 pin deck control
  • Jeremy Garchow
    February 15, 2011 at 4:45 pm
    This is pretty basic stuff.
    [Greg Nicholson] “Since my output is 59.97 is the frame rate the issue?”
    59.94 in 1080i terms is 59.94 FIELDS per second, 29.97 FRAMES per second. Your timeline should be 29.97 not 59.94. If in fact your timeline is ProRes and your clips is ProRes, then you should select a Blackmagic 1080i easy setup by hitting control-q, make a new sequence, drop the clip in.
    Open the Edit to tape window.
    Mark the in point of where you want the tape to start in the ETT window which in your case is 59 minutes, I think. This is provided you have black and coded the tape properly.
    Double check the settings by going to the device settings tab and make sure a 1080i and proper device control is set.
    DRAG THE TIMELINE FROM THE BROWSER TO THE ETT WINDOW AND PLACE IT ON THE ASSEMBLE OVERLAY THAT COMES UP.
    Sorry, I think that’s the third time I’ve said that now.
    The deck should then begin cueing to a 3 second preroll (00:58:57:00), preroll, then start the assemble at 59 minutes.
    Jeremy
  • Jeremy Garchow
    [Greg Nicholson] “oh, because 1080i59.94 is actually 60 FIELDS (approx) and the frame rate is still 30 (approx)”
    Yes.
  • Phil Seymour
    February 15, 2011 at 6:04 pm
    This is a broadcast deck so you should have a 5 second pre roll on it for the servo to lock. Also set the reference to input.
    Phil
  • Jeremy Garchow
    February 15, 2011 at 6:11 pm
    [Phil Seymour] “This is a broadcast deck so you should have a 5 second pre roll on it for the servo to lock. “
    But you will have to modify the preset to achieve that. Let’s see if we can get past step 1 first.
    Jeremy
