Activity Forums Apple Final Cut Pro Legacy Edit to Tape: mono
  • Edit to Tape: mono
    Posted by Bigwavedave on July 16, 2005 at 12:53 am
    We recently upgraded to 5.0.2. When we go to ‘Edit To Tape’ the audio is mono. With we hit play from the time line, stereo. The I/O is the Kona 2 running the 1.1.2 drivers. We have tried every setting we can find in the software, anyone have any ideas?
    Bigwavedave replied 21 years, 2 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    July 16, 2005 at 5:15 pm
    In the lower corner of the edit to tape window there is a button with dots on it.. I think that should be set Ch 1+2, and in the audio outputs tab of the User preferences pane, this too should be set to the default stereo out… checked these?
    Jerry
  • Bigwavedave
    July 19, 2005 at 5:23 am
    Figured it out. The audio was from a CD at 44.1k, when FCP rendered it to 48k it rendered it as mono. all the audio from that point became mono as if a switch turned it to mono. Delete the render files and it is stereo again.
    For now, resample your audio BEFORE importing it.
