Activity › Forums › Apple Final Cut Pro Legacy › Edit to Tape Issues
Kevin Monahan
June 3, 2006 at 6:41 pmThe DSR-11 is not a feature filled deck. It’s the bottom of the line, so you cannot expect things like presettable TC. The SimpleVideoOut “recipe” is certainly a workaround and works only with the one deck. Believe it or don’t, it is not the norm to output in that way. You see, in most NLEs, including Avid, there is no TC out coming from the computer, so you just have to black and code your tape and backtime your pre-show elements for an Edit to Tape
Jean-jacques Briquet
June 4, 2006 at 7:29 pmthanks for your advice, but the original probem is that edit to tape does not work any more for me (refer to original post)
I’ve done it many time with FCP HD, Avid XPro etc….
First time using FCP 5.0.1JJ
