Activity › Forums › Apple Final Cut Pro Legacy › Edit To Tape issues
Edit To Tape issues
Posted by Crys on May 28, 2008 at 8:15 pmHello,
I have been having problems with the Edit To Tape feature in FCP. I am outputting to DigiBeta through SDI and the first time I try to Edit To Tape, I get the color wheel and FCP crashes. I have to Force To Quit to get out of the program, but then I have to do a hard boot because FCP will not start up again and the computer does not restart properly. Once the computer starts up again, I am finally able to Edit To Tape. This happens every single time. Any ideas on how I can fix this?
Thanks in advance for your help!
Specs:
Mac OSX 10.5.2
2 x 2.55 GHz Dual Core Intel Xeon
2GB MHz DDR2 FB-DIMM
FCP 6.0.3
AJA 5.0 Kona LHeCrys replied 18 years, 3 months ago 4 Members · 9 Replies -
Dan Riley
May 28, 2008 at 8:45 pmI have exactly the same issue. I’ve been doing edit to tape to Digibeta via SDI
for 4 years with no problem up through a G5, FCP 5 and my Aurora Pipe Studio.
Now with the Intel Mac Pro and AJA KONA 3 and FCP6 (and up to 6.0.3)
and Sonnet eSATA RAID, your description is exactly what happens here.
I’ve been trying to track it down but have not found any solution.Seems to me it’s gotta be the AJA card and communication issues with the
DigiBeta deck but this is only conjecture. We have a patch bay for changing
connections to the AJA for machine control and maybe it just doesn’t like it
when those connections are changed. Like you said, after a restart, it works.
So probably the shut down and restart clears out the AJA card’s control
issues. Or maybe it’s something completely different.Dan
Adam Taylor
May 28, 2008 at 11:21 pmspooky!!
my system started doing very similar things yesterday. Throughout the day it got worse, culminating in several kernel panics, and not being able to get all the way through startup before the system crashed.
Applecare proved invaluable, and after a couple of procedures the mac is back to perfect health.
First suggestion was to reset the PMU. To do this restart the mac by pressing the power button and then keeping it pressed until you hear a second set of chimes. This didn’t work on my mac so the second suggestion was a PRAM reset.
This is done by hitting the power button, then immediately after hearing the chime press and hold apple, alt, P, R until you hear the mac restart again. This took a minute or two to happen…just keep holding!
That was all it took to reset my system back to normal.
I can’t say it will cure your problem, but you never know!
Adam Taylor
Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
Character Options Ltd
Oldham, UK -
Adam Taylor
May 28, 2008 at 11:24 pmjust noticed your on 10.5 and an Intel mac….i don’t know if my suggestions are relevant as i’m using 10.4.11 on a quad G5.
Adam Taylor
Oldham, UK -
Adam Taylor
May 29, 2008 at 11:59 amUPDATE>>>>>
it seems the solution i put forward yesterday is not a solution after all. My mac has just restarted having the same problem with FCP. Namely, when using the Edit to Tape function the software freezes. Force Quit does not quit it properly and FCP refuses to reload (even though its icon continues to display the triangular marker underneath on the dock).
Adam Taylor
Oldham, UK -
Kevin Monahan
May 29, 2008 at 5:07 pmAre your drives initialized properly with Mac OS Extended?
Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Dan Riley
May 29, 2008 at 6:38 pmIn my case the answer is yes.
If I’m editing with no issues and all is well with FCP 6.0.2 and
SD and HD shows, all kinds of formats…. then the minute I want to
output to tape, then software freezes…… how does that point to
a drive issue? Don’t you think this points toward comm errors?The one area with the Mac OS that is flaky is networking.
You can change a network connection or disconnect an ethernet
cable and the Mac will refuse to shut down or it will freeze.
So I think this is related to the AJA card talking to our
Sony deck or the Panny 1400 deck or the Sony Beta 2800 deck.
Maybe those of us with trouble have something connected wrong
although the AVID MC in the next suite over is not having this trouble
and it goes through the same comm patch bay.Dan
Kevin Monahan
May 29, 2008 at 10:45 pmWell, freezing is often a drive issue in my experience. A lot of people don’t set up their drives right, glad yours is good. You’re are using RS-422 device control?
Have you tried trashing prefs? Perhaps something corrupted them.
Kevin Monahan
Dan Riley
May 29, 2008 at 11:32 pmI should have tried the prefs thing earlier but hate to do it cause I have to
go through FCP and reset everything. I’ve read there is trouble with those
programs that keep track of the prefs in their Leopard and/or FCP6 versions
so I don’t use them. Anyway I’ll try trashing prefs and see if that helps
and report back.Thanks,
Dan -
Crys
June 6, 2008 at 8:57 pmWell, I finally resolved the problem! For those that have AJA LHe:
I called AJA tech support and they sent me a text file and told me to follow these steps:
1. Quit FCP and Kona control Panel
2. Take the .txt from the attached (for those that want the txt file, you can email me at crys94ATyahooDOTcom) and go to
3. Library > Applications Support > FCP System Support > Plugins
4. Drop it there, restart, and launch FCP
After that, they told me to download the latest update, KONA LH/LHe Drivers Version 5.1 NDD.
Before dropping in the text file, you might want to try the update first and see if that solves your problem. Ever since I followed these steps, everything has been working great!
