Activity Forums Apple Final Cut Pro Legacy edit to tape – insert edit not frame accurate
  • edit to tape – insert edit not frame accurate
    Posted by Peter Wolsey on August 20, 2008 at 5:29 pm
    Trying to insert edit a new credit roll at the end of a 1 hour documentary, but at the insert point there’s always a duplicate frame recorded. Looks like a common problem according to the last 3 months posts, but I haven’t been able to find any definitive answer.
    I’m editing in PAL SD and mastering on Digibeta, using a Blackmagic card. I’ve heard that using a sync pulse generator to lock all the hardware together might help. Any ideas, before I have to go through the process of laying off the whole 1 hr doc again? We have to produce 6 copies of the TX master so this will be really time consuming!
    Thanks, Pete
    David Bogie replied 18 years ago 2 Members · 1 Reply
  • David Bogie
    August 20, 2008 at 9:38 pm
    Most decks require careful experimentation to determine the offset required for things to happen between the computer and the card and the deck’s ability to interpret the Mac’s commands.
    Is the duplicate frame coming from the timeline? Can’t you just set your in point on the timeline one frame later?
    bogiesan
