Activity Forums Apple Final Cut Pro Legacy Edit to Tape in FCP: Decklink misbehavior
  • Edit to Tape in FCP: Decklink misbehavior
    Posted by Jaap Verdenius on July 8, 2007 at 5:59 pm
    When I go Edit to Tape in FCP I find that on the first frame on tape there is one field doubled – causing a jerky movement at this point. This makes it virtually impossible to make a decent video insert on tape.
    NB This is not a playback offset issue. You cannot solve the problem that way as a different offset will not change the fact that the first frame coming from the Decklink card has a duplicated field
    Anyone having the same problem here?
    Jaap Verdenius
    PS Blackmagic acknowledged the problem to me but strangely they also seem uninterested to solve it – they told me they didn’t address the issue in their 6.3 driver. I wonder if solving the problem would cost more than 15 minutes of coding…?
    G5 2×2.7
    OS 10.4.9
    Decklink Pro, BM 6.2
    Ingo Schulten replied 19 years, 1 month ago 2 Members · 1 Reply
  • Ingo Schulten
    July 11, 2007 at 3:15 pm
    we have the exact the same problem here, and nobody was able to help us so far. So we hope that blackmagic will fix this problem soon;-)
    Greetings from Cologne
    Ingo
