Activity Forums Apple Final Cut Pro Legacy edit to tape HD looks low res
  • edit to tape HD looks low res
    Posted by Todd Hallam on July 16, 2009 at 10:45 am
    Trying to perform an insert edit of a previously output HD 29.97 timeline. New Kona 3 installed since this program was put on tape (previously had a Kona LH). Sequence is fully rendered all settings set to 1080i 29.97 (including the Aja control box), deck is set for 29.97.
    Everything plays through and looks great through the machine and on the monitors until I initiate Edit to Tape. It performs the edit and the picture starts looking great but after about 30 or 40 frames looks somewhat blocky like it has been scaled up (jagged edges). During ETT the Kona control box settings are reading fine.
    Please help
    FCP 6.05
    OSX 10.5.7
    Todd Hallam
    SideshowFX
    Pixel Corps
    FXC:JA:Final Comp
    Todd Hallam replied 17 years, 1 month ago 2 Members · 6 Replies
  • Todd Hallam
    July 16, 2009 at 11:28 am
    Looking at it a little closer I noticed that the timeline RT setting shows Playback Quality High is greyed out (Dynamic is checked). I have heard this could be a ram issue. Is that true? (Another sequence at 720p has Playback High available)
    Todd Hallam
    SideshowFX
  • Richard Sanchez
    July 16, 2009 at 1:56 pm
    I once had this issue on an eight core mac pro. High quality was greyed out, which made for bad tape layoffs. we opened the tower and noticed it was setup with 10 gigs of ram. 4 2gb modules and 2 1gb modules. As soon as we pulled the 2 1gb modules, were able to select high quality and all was well.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Todd Hallam
    July 16, 2009 at 1:59 pm
    That’s what I figured. Thanks.
    Todd Hallam
    SideshowFX
  • Todd Hallam
    July 16, 2009 at 2:02 pm
    Looking at the system, we have 4 2gb sticks. I assume they are still in pairs and would therefore have to pull 4gigs of ram. Is that right?
    Todd Hallam
    SideshowFX
  • Richard Sanchez
    July 16, 2009 at 2:29 pm
    4 2gb should be fine. That is weird. Are they different manufacturers? Likewise, are they different speed ram? (I.E. one being 677 and the other 800)
    Richard Sanchez
    North Hollywood, CA
  • Todd Hallam
    July 16, 2009 at 2:37 pm
    Just checked – same speed, same manufacturer – ran TTPro and the memory test passes. We may try and place them in different slots.
    Todd Hallam
    SideshowFX
