Activity › Forums › Apple Final Cut Pro Legacy › Edit to Tape glitch
  • Edit to Tape glitch
    Posted by Chris Poisson on September 3, 2008 at 3:19 pm
    Edit to Tape is not working properly. It loads okay, starts okay but no picture to tape. I can see the movie in the ETT window, but it’s not going to tape, I only get audio.
    The Kona control panel shows everything is connected, blue on video in and out, analog to the Beta UVW 1800. It is connected directly to the Kona, not going through the patch bay. So with what all seems to be working right, it ain’t.
    G5 dual 2 gig with 4.5 gigs RAM. OS 10.5.4 QT 7.5 FCS 6.0.4.
    Have a wonderful day.
    Tom Matthies replied 18 years ago 4 Members · 7 Replies
  • 7 Replies
  • Chris Poisson
    September 3, 2008 at 3:24 pm
    I forgot, yes, I checked all my audio/video settings and have my RS422 cable hooked up properly.
  • Walter Biscardi
    September 3, 2008 at 3:46 pm
    What audio video settings are you using? We have the same UVW-1800 and just laid off about three masters yesterday with the AJA 8bit SD Uncompressed settings. This is with all the latest updates on a Mac Pro Quad 3.0.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Evan Schafer
    September 3, 2008 at 3:50 pm
    Are you downconverting HD material to the Beta deck? If so, have you set it up to downconvert in the Kona control panel or is it trying to send the HD signal to the deck?
  • Chris Poisson
    September 3, 2008 at 5:24 pm
    This job is set up as SD 8bit uncompressed, no downconvert. My settings are 8 bit uncompressed easy setup. This whole rig used to work great before my recent Ex made me sell the house, thereby forcing a studio move, and it’s never been the same since the move. Damit.
  • Evan Schafer
    September 3, 2008 at 5:35 pm
    Assuming you are sending it component, in the Kona control panel, do you have the analog out to send “Component (Beta)”?
    Excuse the obvious but, is the Component input on the front of the 1800 selected ?
    Is the Kona selected in FCP (in the View menu) for video out? Should already be if you selected the Kona in Easy Set up.
  • Chris Poisson
    September 3, 2008 at 6:19 pm
    Hi Evan,
    Yes, and yes, but I’ll check on the third point.
  • Tom Matthies
    September 4, 2008 at 5:46 pm
    Chris, also make sure that on the back of the deck that the component inputs are set to “see” the BNC inputs (labeled Component 2) and not the “dub” multi-pin input (labeled Component 1). If the switch on the back of the deck is flipped, it won’t see the inputs from your Kona board and you will have no picture.
    Just a thought
    Tom
