Activity Forums Apple Final Cut Pro Legacy Edit to Tape glitch
  • Edit to Tape glitch
    Posted by Smith Glover on October 8, 2009 at 8:17 am
    hello
    i have a pretty decent understanding of FCP but am having a hell of a time with edit to tape at the moment. it is working fine on my G5 with FCP 6, but on my G4 with 5.04 i am having the following issues: once edit to tape starts, the deck only records the first still image that comes up on the screen (the first frame of the piece i am outputting) and that is it- won’t record, even though the video is playing back fine mirroring on desktop. actually- it is laying down time code, which is odd, just now video past the first frame. i tried print to tape and it just lays down black.
    i have changed settings and used firewire basic as well as firewire for my Device Control Preset. The project is 30 fps 16:9 standard def. i haven’t encountered this before- any ideas?
    thanks
    Chris Poisson replied 16 years, 11 months ago 4 Members · 5 Replies
  • Michael Gissing
    October 8, 2009 at 8:33 am
    Some basic info might help. What deck? What are your sequence settings? Do you have a firewire drive and a firewire deck connected at the same time?
    Have you tried the usual – trash prefs etc. Can you play the sequence and crash record on the deck?
  • Smith Glover
    October 8, 2009 at 8:41 am
    Michael
    Thanks for your response. I tried both a Sony HVR-M1OU and my old XL1 camera. Sequences settings are DV NTSC, anamorphic, 30fps progressive. Just a deck, not a drive.
    I did trash the preferences and no change. I did not try to crash record- I haven’t done that before and don’t know how.
    Thanks again,
    Smith
  • Steve Eisen
    October 8, 2009 at 11:53 am
    Try print to tape.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Steve Eisen
    October 8, 2009 at 12:56 pm
    I meant to say Print to Video.
    Steve Eisen
    Board of Directors
  • Chris Poisson
    October 8, 2009 at 4:16 pm
    Whenever I have this problem, nearly all the time trashing prefs and restarting fixes it. But you also my need to dump your caches, use Leopard Cache Cleaner for that.
