Activity Forums Apple Final Cut Pro Legacy Edit to Tape Frame Accuracy Problems with SD and Kona LH
  • Edit to Tape Frame Accuracy Problems with SD and Kona LH
    Posted by Neil Krupnick on August 4, 2008 at 9:35 pm
    I am editing on Final Cut Pro 6.0.4 on a Power Mac G5 (OS 10.4.11) using the Kona LH card (5.1). When I edit a drop frame sequence to tape (SONY Digi Beta), the frame accuracy gets all screwed up after the initial insert point (which occurs at the right timecode, usually 00;58;40;00 for a minute of bars and tone). I have had some success cheating the sequence by deleting 1 frame before the first edit occurring after the start of the sequence but this doesn’t always work.
    Has anyone else had these problems and is there a solution other than cheating?
    Neil Krupnick replied 18 years, 1 month ago 2 Members · 2 Replies
  • Chris Poisson
    August 5, 2008 at 12:09 am
    I have the same rig and mine has never done that. I’d try trashing prefs.
    Have a wonderful day.
  • Neil Krupnick
    August 6, 2008 at 2:48 pm
    how do i trash the preferences and does final cut immediately restore the default prefs? thanks chris.
