Activity › Forums › Apple Final Cut Pro Legacy › Edit to tape doesn’t do INSERTS
  • Edit to tape doesn’t do INSERTS
    Posted by Bibomishriky on January 1, 2006 at 5:22 pm
    i am using FCP 4.5 on G5 dual, using a sony DSR 11.
    When i do edit to tape command , i can assemble but inserts doesn’t work at all, i tried using other decks but it doesn’t seem to work at all, any one has any tips?
    Jamie Worsfold replied 20 years, 8 months ago 3 Members · 4 Replies
  • John Pale
    January 1, 2006 at 6:24 pm
    Most DV decks do not support Insert editing, only Assemble.
    If you connect to a deck that supports it, like a Beta SP or Digibeta deck, it works fine.
    Happy New Year
  • Bibomishriky
    January 2, 2006 at 12:32 pm
    thanks man ofr the response, do you have any recommendation on Dv deck that supports inserts, or how do i look for them when going through specs, Thanks again
  • John Pale
    January 2, 2006 at 5:29 pm
    I think the DSR 2000 and 1800 can do it. (and I believe, only with DVCAM not miniDV)
  • Jamie Worsfold
    January 4, 2006 at 2:51 pm
    As far as I’m aware it’s a Firewire issue (somebody correct me if I’m wrong!). If you’ve got a deck with RS422 control on then you should be able to do it, but the Firewire control won’t allow inserts.
