Activity Forums Apple Final Cut Pro Legacy Edit to tape
  • Posted by John Little on July 6, 2006 at 1:29 pm
    I am working with FCP 5.0.4 on a Mac G5. When I try to do an “Edit to tape” I set the TC I want in the “IN” field, however when the edit is made the machine makes the edit approximately 14 frames early. I am recording from a DV50 timeline to a Panasonic AJ SD955. The machine control and media are being fed via firewire. The machine records everything fine, just not at the TC I set. Is there possibly a setting somewhere that I have missed that would correct this problem?
    Michael Alberts replied 20 years, 1 month ago 3 Members · 3 Replies
  • Ramendemon
    July 6, 2006 at 3:30 pm
    I have heard that Firewire is not frame accurate. This could be the answer. Is it off 14 frames everytime? If so, is there a way you can adjust your in point to correct for it?
  • John Little
    July 6, 2006 at 4:18 pm
    The 14 frames seems to be an average. It is not always exactly 14. It is only a REAL problem when I want to correct something already on tape and I have to re-output the entire show since it is not frame accurate.
  • Michael Alberts
    July 6, 2006 at 8:11 pm
    Try controlling the deck via RS-422 and see if you get frame accurate assemble edits that way.
    Michael Alberts
    Ambidextrous Productions, Inc.
