Activity Forums Apple Final Cut Pro Legacy edit to tape
  • Posted by Christobasho on March 30, 2006 at 9:56 am
    Hello!
    I am trying to edit my sequence to a mini DV tape.
    My tape is coded correctly and my in-point is valid, but on the tape, the sequence is always one or two frames before or after the in-point. And the difference is never twice the same. Why can’t I edit my sequence properly? Is it due to the mini-DV format, should I edit it to a DVcam tape?
    Thank you for helping me out with this (very-annoying) problem
    C.
    Debe replied 20 years, 5 months ago 2 Members · 1 Reply
  • Debe
    March 30, 2006 at 4:49 pm
    It’s a limitation of firewire.
    To be completely frame accurate, you need to use a deck that can be controlled by a machine language known as RS-422.
    AFAIK, you can’t get that via firewire.
    debe
