Activity Forums Media 100 Edit Suite problem
  • Edit Suite problem
    Posted by Brian Uhler on May 18, 2011 at 9:00 pm
    I am trying to digitize some footage from a beta deck. However every time I hit the Acquire button I get the following message “Could not switch to digitize panel because the Media 100 Suite System is locked up”. I was working fine yesterday. I am on the newest version of media and my drivers are all up to date.
    I even reinstalled Media thinking that might do something and same problem.
    Anyone have any ideas????
    Floh Peters replied 15 years, 4 months ago 3 Members · 2 Replies
  • Paul Crowe
    May 19, 2011 at 12:35 am
    How is your drive space? Are you digitising to the same drive as yesterday? If not perhaps the new one is not fast enough?
    Dunno, just ideas.
    Cheers
    Paul
  • Floh Peters
    May 19, 2011 at 10:10 am
    You should delete your “Current Configuration” file in YourHomeFolder->Library->Preferences->Media 100 Suite Preferences. Most likely there is a setting that went wrong within this file. If you remember which configuration you used, you could try to delete the configuration file (located in the same folder) as well.
