Edit Suite Nightmare Realization – Can I convert 29.97 fps footage to fit seamlessly into 25fps timeline?
So, I’m in the midst of a short documentary project. All the shooting is done and dusted, with no chance of any pickups or re-shoots.
I jump into Final Cut to get the ball rolling and to my horror, one of the two cameras I was using was shooting at 29.97. The project must be delivered at 25 fps and all the footage from the other camera was shot at 25.
Unfortunately, I also used both cameras for a two camera setup during the interview. I really need to be able to cut between the two cameras with audio sync.
I feel like I’m sort of up shit creek but what are my options here? Is there any way to convert and integrate the 29.97 footage seamlessly into a 25fps timeline? Is hardware conversion flawless?
Will conforming the footage to 25 and then speeding up work or will there still be jitters?
If you’re wondering how this happened, I was shooting on hacked GH2’s and somewhere in the hacking process obviously something went wrong. I should have checked after the first round of shooting but time pressures meant that I didn’t. At the end of the day it’s my fault but any suggestions would be hugely appreciated.
