Activity › Forums › Adobe Premiere Pro › Edit suggestion of boring static interview with no B cut source available
  • Edit suggestion of boring static interview with no B cut source available
    Posted by Anhtu Vu on March 3, 2014 at 6:10 pm
    I need some clever suggestions for editing a boring static interview where the subject is sitting facing one cam. I need to cut a 2 min video out of the 15 min interview and i have no B roll sources available at all.
    So basically, what are some of your preferred techniques for masking jump cut when you have no B roll available ??
    Link to you tube or vimeo would be great. Thx
    Fabio Frey replied 12 years, 6 months ago 6 Members · 5 Replies
  • Shane Ross
    March 3, 2014 at 6:22 pm
    Cut the interview clip up and scale up the footage for a bit, then go back. Cut at points where you either have to cut (chopping out words), or where you want to add emphasis to what they are saying.
    Next time, ask that they shoot at least two cameras….or get b-roll
    Shane
    Little Frog Post
  • Andrew Drachman
    March 3, 2014 at 9:12 pm
    You could try using stock footage, if it is relevant. I’ve used Shutterstock.com or videoblocks.com in the past.
  • John Pale
    March 4, 2014 at 1:47 am
    “You could try using stock footage, if it is relevant.”
    You mean like this?
    https://youtu.be/v2mLAajm7ZY
  • Larry Asbell
    March 5, 2014 at 3:20 am
    No not that B-roll, this B-roll:
    https://www.youtube.com/watch?v=SItFvB0Upb8
  • Fabio Frey
    March 7, 2014 at 1:04 am
    Something I’ve done before is put film flares or some other type of overlay like that one it, it kind of helps explain the jumpcut and makes it feel more natural. Realize though that not every client will like that.
