Activity Forums Avid Media Composer Edit Share and 2GB file limit
  • Edit Share and 2GB file limit
    Posted by Al J. marschke on May 9, 2008 at 11:53 am
    Can an Avid Adrenaline on a PC with Edit Share be set up to handle files larger than 2 GB? This 2GB limit with HD is really a hassle with XDCam HD. Shooting with the Sony’s 355s @ 35MB VBR that’s only a few minutes. I understand that I can do proxy first but that’s not always an option. I have work arounds but I’d like a solution to the 2GB limit unless its a PC thing.
    Thanks in advance.
    AL J. Marschke
    BluMars Media
    Pittsburgh, PA
    Todd Smaretsky replied 18 years, 2 months ago 4 Members · 3 Replies
  • Bobby Calautti
    May 9, 2008 at 2:53 pm
    I always been under the impression its a PC thing.
  • Dylan Reeve
    May 10, 2008 at 4:17 am
    It’s a FAT32 thing – FAT32 is often used on disks needing to be accessed across Mac and Windows systems as it’s the most widely supported format.
    However NTFS in Windows has no 2GB file limit and should work with Editshare I’d have thought.
  • Todd Smaretsky
    June 17, 2008 at 5:43 pm
    Not true. Fat32 can export 4 GB. I am having the same problem – i have MC 3 and can only export 2GB using quick time. This is ridiculous.
