Activity › Forums › Apple Final Cut Pro Legacy › Edit SDI on MBP with Apple Pro Res or DV 50 ?
  • Edit SDI on MBP with Apple Pro Res or DV 50 ?
    Posted by Kaya Hacaloglu on April 16, 2008 at 12:32 am
    Hello,
    I will be receiving footage shot on DigiBeta shortly. I will have them transfered to my external firewire 800 drive thorugh a MacPro;
    I am confused whether I should capture and edit using Apple Pro Res 422 SD PAL, or will DV 50 (also 422) should the job as well. I am using FinalCut 6.02 on a MAcBookPro 2.4 with 2 Gigs of Ram. I have 1 TB of RAID 0 drive system connected through the firewire 800 bus. Will the bandwith of Apple Pro res slow my system albeit the high quality, or should I stick with DV 50 ?
    Both are 8 bit quality, am I right ?
    Thank you
    Kaya
    Kaya Hacaloglu replied 18 years, 5 months ago 2 Members · 2 Replies
  • Walter Biscardi
    April 16, 2008 at 2:39 am
    ProRes on a MacBook Pro will be iffy without an AJA Io HD which provides all the hardware acceleration onboard for that format.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Kaya Hacaloglu
    April 16, 2008 at 3:44 pm
    Hi Walter,
    Thanks for the reply. I am planning on editing SD footage, not HD..I would have used DV50 but have heard issues with color regarding this specific codec. I am plannig on capturing using Kona to my FW800 drive and editing.
    What do you mean iffy ? You mean the processing power wouldnt be sufficent ?
    Kaya
